The receivers negotiate during the binding process the protocol and resolution.
So you need to make sure that both the receivers that you use are the same protocol and resolution (1024 or 2048) If everything is the same they will bind at the same time and work like you want to with a smaller 6 channel or whatever operating the arms/head and the main rx operating the flight controls.
You can even bind them one at a time and they will both respond.
