Hello guys,
I have acquired the first Odyssey sport jet to arrive in Israel by Sky Toys.
Top RC model is a very well known company in the scale RC prop planes field, that recently started producing jets.
once i saw this jet at Jetpower 2016 in Germany, i was hooked! it is simply gorgeous and the price was hard to beat!
The quality seems up there with the best of them and so is the finish, everything seems very lightweight!
Jet comes in a variety of colors and i understand there might even be an option for custom schemes.
so, i will make a build thread about this exciting new jet and will keep you guys updated with anything i find while im at it.
The jet's specs:Length: 2320mm/91in
Wing Span: 2190mm/86in
Turbine: 10~14kg turbine
Radio: Min. 9 ~ 11 Servos required
Description:
1. Full composite construction.
2. All surface prepainted,decals applied and clear coated
3. Scale cockpit included.
4. Detachable main wing, fuselage and tailplane & vertical fin for easy transportation;
5. Removable hatch on fuselage for easy access into the plane and change accessories;
6. Functional flaps for smooth landing.
7. High quality CNC Alu push rod included
8. More than 95% assembled complete in factory.
9. Tail tube and fuel tank included.
10. Electric landing gear with electric brakes.
i am going to be using the following gear on the jet:
- ATJ 140 SV turbine (LOVE this engine!)
- Blue Bird BLS-3507 brushless metal gear high torque servos
- Emcotec DPSI RV Mini 5 power system with redundant lipo batteries
- Cortex Pro gyro
- Futaba 18MZ for control
Some pics as it is "Out of the box". and im attaching a copy of the manufacturer manual.
Thanks to Sky Toys for making this exciting kit available locally.
