RCU Forums - View Single Post - Mousse can logic?
Old 02-18-2017, 05:56 PM
tony0707
I use the same fuel mixture and run my OS75 ax on an APC12/6
The engine is a true powerhouse in a 60 size airframe
Vertical performance is the true test of a props performance
You prop an airframe not an engine
Find the prop that pulls the plane straight up best
It is the prop that will pull you thru your manuvers best
Enjoy
