Old 03-04-2017, 09:03 AM
  #159
sahartman21
Default Build an Ashley MM
There are a few Ashley MMs under construction. Below are some of the locations and settings:
  1. The CG should be located approximately 3 3/4" from the leading edge of the wing (at the wing saddle).
  2. The axles should be approximately 2 1/2" from the leading edge of the wing (at the gear).
  3. The low rate elevator throw is approximately 1/8" up and less down. High rate is slightly more throw.
  4. The low rate rudder throw is approximately 1/4" each way. You hold full rudder on launch. High rate should have lots of throw.
  5. The low rate aileron throw is approximately 3/16" each way. High rate should have lots of throw.
ID:	2203862   Click image for larger version
