On a small tab like that.. I would probably just lay my film down.. get it close to position(no heat yet..).. then just slit the covering the length of the tab, where the tab protrudes... thereby letting the film contour down around the tab...then as I always do, just smooth out that covering by hand as much as I can before applying any heat anywhere... and even then not hitting that slit with heat until the near the very end.... then just simply seal it around the tab. One slit would do it I do think though... its not a monster at all..
