Thank you.
The 'truck' is actually my wife's Ford Excursion diesel, which should be large enough (with the seats folded) for the Snowbird. I also have the laser cut fuselage cradle (from a fellow RCU member) which should help with transport; really well designed and built accessory.
If I'm lucky, I can fit the Snowbird plus the Turbinator at the same time...if not, then one stays home!
