RCU Forums - View Single Post - Servo connectors
Old 04-03-2017 | 12:16 AM
mauryr
Originally Posted by JimBrown
That would depend entirely on the voltage being used. And it is what is drawing the power that determines the amps being sent. One does not simply send a set amount of amps down a circuit.
Volts times Amps = Watts.
Our servo connectors are capable of 750 watts.
As long as the volts being used times the amps being drawn does not exceed 750 watts, you're good to go.
The next limiting factor is the wire size and its resistance.
...jim
OMG, how did you get the assumption power has anything to do with this? .... Please stop posting misinformation, somebody might actually believe this post made any sense !.....
