Like to share with you our latest addition the CG wizard.
Designed by Daniël Maiorano & Sandor Kruise
Build in the EU.
CG wizard is a Helpfull tool that lets you find the CG of your aircraft in 5 easy steps.
we looked carefull to our competition and we seen that most of them around are difficult to use and set up.
and sometimes needs a 50 pages manual to use it.
also we thought to implement all tools you WILL need , and not to buy external stuff.
all is connected thru USB cables.
The CG wizard is easy to setup and use.
5 steps needed only!
1.Set CG mark on aircraft
2.Measure aft Sensor to front sensor
3.Point the build in laser to measure the CG
4.Give distance in app
5.add or lose weight , you can see on app when CG is reached!
Thats it!!! no usage of plumbs , tape , giving to much data.
extremely easy to use!
Complete CG set contains the following :
3 x sensors Laser cut of 6mm CASTED acryl
1 x Central box with BlueTooth and Build in LaserHelp (C)
3 x USB cables to connect sensors to Central Box
1 x Charge Lead
1 x Powerbank 2900 Mah to power the device
Works both on IOS and Android Apps are for FREE!
Max aircraft weight 40 KG
Price is less then a decent Digital high end servo!
Manual here : https://www.dropbox.com/s/niyjwse55q...anual.pdf?dl=0
any questions ? shoot!
Br Sandor Kruise
