Kenneth, turnigy 4074 - 2200 kv specs; 3000 watts power - 120 amps max current - diameter 47 mm .
turnigy 3674 - 2200 kv specs; 1750 watts power - 70 amps max current - diameter 43 mm. both with cooling jackets.
i wouldn,t risk using a 120 amp esc with either motor , must use 180 amp.
is your propellor very sharp ? in pic it does look to be rather blunt but maybe thats the pic.
also as Patric said make sure you have very good connections at the plugs for both the battery to esc and the motor to esc. even if you fit better quality gold plated connectors .
