Thread: Cutting out
Old 04-12-2017, 04:38 AM
launchpad51
i did not check to see if it was hot or not.i have a temperature gauge that i will use.i tried another esc and same thing.i will try to reprogram the esc later and will get back to you with results.also i checked all the wiring had to redo 2 wires as they were frayed so i cleaned the wires and put shrink tubing to cover bare wires that was for the steering .it was running fine the last time i used it.hopefully i sort this out soon as my granddaughter want to do some bashing.
