Aha ok..Yes I agree it is better to keep the esc close to the battery,, Think I read about that model with balsa and foam, yes maybe that is the way forward..
I have experimented a lot with high pwr setups and the most insane I used is a 3700Watt motor 800kV on 6S,, (I even tried 8S once), But as far as I knowt there is no lipos available
that can give me reasonable time in the air, and it is off course a heavy setup, I like to test and have fun with crazy much power..
Right now I am considering to use my last foam-core wing for my next NS, but not so shure it will be lighter than the original wing design..
Thank you for your input.
//Rob
