So on to the rear support. The needle bearing in the grommet has worked for me so that's what I'll use here. The frame is held in the fuse with the rubber grommets and the formers glued in to the fuse. I like to make everything up outside the plane then fit it to the fuse assembled. Just as with the front former don't have it tight anywhere. I had to do a little grinding here and there to get it right before I glued it in with the Hysol.
Here's the nozzle I use when I glued this stuff in. BTW, after using it if you put it in the freezer it will stay good for a day or two. You can take it out and re-use it. I warm it up a bit with a heat gun after taking it out of the freezer. I also mark it and the cap so I know what orientation to install it.
I like to use some of the Hysol around the landing gear mounts. Just a little insurance if you have a rough landing. When this glue cures I'll remove the rear support and the power system and glue everything up solid on both sides of the formers. Now on to other stuff!
