Negative angle of incidence on the ground during take off is forcing the jet to hug the ground. Faster the jet goes, the worse it gets. Should have just made a larger nose gear hole. Either buy a new nose strut and make a bigger hole, because if you reduce the mains by 3/8ths then you may have main retraction issues.
