Gaspar Can you look at this log
Today after the 6th flight of the day I started the engine for the 7th flight, went through all of start up taxied to the run way moved to full throttle it spooled up and then poof a cloud of white smoke. brought it back to the pits. tried to start up first time it wouldn't start. So I turned off everything and let it set for a few minutes. When I tried again, started fine went to run so I increased to full throttle for a few seconds and then back down then all the way up and back down the 3rd or 4th time it started popping and then flamed out. after this time I looked on the screen and it said it cut off due to low RPM. I also thought I saw on the screen where it didn't seem like the rpm was correct while on that last run.
here's the last run in text also I might add there was never any bubbles
w Run , 5400, 104, 8, 25%, 7.5 V,
New Run , 5400, 104, 8, 25%, 7.5 V,
SwitchOv T=105C Rpm 5450 Pw 2, 5400, 104, 8, 25%, 7.5 V,
SwitchOv T=106C Rpm 5480 Pw 2, 5500, 104, 8, 25%, 7.5 V,
SwitchOv T=107C Rpm 5520 Pw 2, 5500, 104, 8, 25%, 7.5 V,
SwitchOv T=108C Rpm 5560 Pw 2, 5600, 108, 8, 25%, 7.5 V,
SwitchOv T=110C Rpm 5610 Pw 2, 5600, 108, 8, 25%, 7.5 V,
SwitchOv T=111C Rpm 5650 Pw 2, 5700, 108, 8, 25%, 7.5 V,
SwitchOv T=112C Rpm 5690 Pw 2, 5700, 112, 8, 25%, 7.5 V,
SwitchOv T=114C Rpm 5750 Pw 2, 5800, 112, 8, 25%, 7.5 V,
SwitchOv T=115C Rpm 5810 Pw 2, 5900, 112, 8, 25%, 7.5 V,
SwitchOv T=117C Rpm 5870 Pw 2, 5900, 116, 8, 25%, 7.5 V,
FuelRamp T=119C Rpm 5940 Pw 3, 6000, 116, 12, 25%, 7.5 V,
FuelRamp T=121C Rpm 6050 Pw 3, 6200, 120, 12, 25%, 7.5 V,
FuelRamp T=123C Rpm 6200 Pw 3, 6400, 120, 12, 25%, 7.5 V,
FuelRamp T=126C Rpm 6370 Pw 3, 6600, 124, 12, 25%, 7.5 V,
FuelRamp T=129C Rpm 6570 Pw 3, 6800, 128, 12, 25%, 7.5 V,
FuelRamp T=133C Rpm 6750 Pw 3, 7000, 132, 12, 25%, 7.5 V,
FuelRamp T=137C Rpm 6940 Pw 3, 7200, 136, 12, 25%, 7.5 V,
FuelRamp T=141C Rpm 7120 Pw 3, 7300, 140, 12, 25%, 7.5 V,
FuelRamp T=145C Rpm 7300 Pw 3, 7500, 144, 12, 25%, 7.5 V,
FuelRamp T=150C Rpm 7470 Pw 3, 7700, 148, 12, 25%, 7.5 V,
FuelRamp T=155C Rpm 7640 Pw 3, 7800, 152, 12, 25%, 7.5 V,
FuelRamp T=160C Rpm 7800 Pw 3, 8000, 160, 12, 25%, 7.5 V,
FuelRamp T=165C Rpm 7940 Pw 3, 8100, 164, 12, 25%, 7.5 V,
FuelRamp T=169C Rpm 8090 Pw 3, 8300, 168, 12, 25%, 7.5 V,
FuelRamp T=173C Rpm 8230 Pw 3, 8400, 172, 12, 25%, 7.5 V,
FuelRamp T=177C Rpm 8360 Pw 3, 8500, 176, 12, 25%, 7.5 V,
FuelRamp T=182C Rpm 8490 Pw 3, 8600, 180, 12, 25%, 7.5 V,
FuelRamp T=187C Rpm 8620 Pw 3, 8800, 184, 12, 25%, 7.5 V,
FuelRamp T=191C Rpm 8750 Pw 4, 8900, 188, 16, 25%, 7.5 V,
FuelRamp T=196C Rpm 8900 Pw 4, 9000, 196, 16, 25%, 7.5 V,
FuelRamp T=201C Rpm 9030 Pw 4, 9200, 200, 16, 25%, 7.5 V,
FuelRamp T=206C Rpm 9140 Pw 4, 9300, 204, 16, 25%, 7.5 V,
FuelRamp T=211C Rpm 9260 Pw 4, 9400, 208, 16, 25%, 7.5 V,
FuelRamp T=216C Rpm 9380 Pw 4, 9500, 216, 16, 25%, 7.5 V,
FuelRamp T=221C Rpm 9500 Pw 4, 9600, 220, 16, 25%, 7.5 V,
FuelRamp T=227C Rpm 9620 Pw 4, 9700, 224, 16, 25%, 7.5 V,
FuelRamp T=232C Rpm 9720 Pw 4, 9800, 232, 16, 25%, 7.5 V,
FuelRamp T=237C Rpm 9830 Pw 4, 9900, 236, 16, 25%, 7.5 V,
FuelRamp T=242C Rpm 9930 Pw 4, 10000, 240, 16, 25%, 7.5 V,
FuelRamp T=246C Rpm 10030 Pw 4, 10100, 244, 16, 25%, 7.5 V,
FuelRamp T=251C Rpm 10140 Pw 4, 10300, 248, 16, 25%, 7.5 V,
FuelRamp T=257C Rpm 10270 Pw 4, 10400, 256, 16, 25%, 7.5 V,
FuelRamp T=263C Rpm 10390 Pw 4, 10500, 260, 16, 25%, 7.5 V,
FuelRamp T=268C Rpm 10520 Pw 4, 10700, 268, 16, 25%, 7.5 V,
FuelRamp T=274C Rpm 10650 Pw 4, 10800, 272, 16, 25%, 7.5 V,
FuelRamp T=279C Rpm 10790 Pw 4, 10900, 276, 16, 25%, 7.5 V,
FuelRamp T=285C Rpm 10930 Pw 5, 11100, 284, 20, 25%, 7.5 V,
FuelRamp T=290C Rpm 11080 Pw 5, 11200, 288, 20, 25%, 7.5 V,
FuelRamp T=296C Rpm 11240 Pw 5, 11400, 296, 20, 25%, 7.5 V,
FuelRamp T=302C Rpm 11390 Pw 5, 11600, 300, 20, 25%, 7.5 V,
FuelRamp T=308C Rpm 11530 Pw 5, 11700, 308, 20, 25%, 7.5 V,
FuelRamp T=313C Rpm 11670 Pw 5, 11800, 312, 20, 25%, 7.5 V,
FuelRamp T=318C Rpm 11810 Pw 5, 12000, 316, 20, 25%, 7.5 V,
FuelRamp T=323C Rpm 11950 Pw 5, 12100, 320, 20, 25%, 7.5 V,
FuelRamp T=329C Rpm 12090 Pw 5, 12300, 328, 20, 25%, 7.3 V,
FuelRamp T=334C Rpm 12230 Pw 5, 12400, 332, 20, 25%, 7.3 V,
FuelRamp T=340C Rpm 12380 Pw 5, 12600, 340, 20, 25%, 7.5 V,
FuelRamp T=345C Rpm 12520 Pw 5, 12700, 344, 20, 25%, 7.3 V,
FuelRamp T=350C Rpm 12650 Pw 5, 12800, 348, 20, 25%, 7.5 V,
FuelRamp T=350C Rpm 12780 Pw 5, 12900, 348, 20, 25%, 7.3 V,
FuelRamp T=350C Rpm 12920 Pw 6, 13100, 348, 24, 25%, 7.5 V,
FuelRamp T=350C Rpm 13050 Pw 6, 13200, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 13190 Pw 6, 13400, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 13340 Pw 6, 13500, 348, 24, 25%, 7.5 V,
FuelRamp T=350C Rpm 13490 Pw 6, 13700, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 13640 Pw 6, 13800, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 13790 Pw 6, 14000, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 13930 Pw 6, 14100, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 14080 Pw 6, 14200, 348, 24, 25%, 7.5 V,
FuelRamp T=350C Rpm 14220 Pw 6, 14400, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 14370 Pw 6, 14500, 348, 24, 25%, 7.5 V,
FuelRamp T=350C Rpm 14520 Pw 6, 14700, 348, 24, 25%, 7.3 V,
FuelRamp T=350C Rpm 14650 Pw 6, 14800, 348, 24, 25%, 7.5 V,
FuelRamp T=351C Rpm 14770 Pw 6, 14900, 348, 24, 25%, 7.5 V,
FuelRamp T=352C Rpm 14890 Pw 7, 15000, 352, 28, 25%, 7.3 V,
FuelRamp T=356C Rpm 15020 Pw 7, 15200, 356, 28, 25%, 7.3 V,
FuelRamp T=359C Rpm 15150 Pw 7, 15300, 356, 28, 25%, 7.5 V,
FuelRamp T=362C Rpm 15280 Pw 7, 15400, 360, 28, 25%, 7.3 V,
FuelRamp T=366C Rpm 15430 Pw 7, 15600, 364, 28, 25%, 7.3 V,
FuelRamp T=370C Rpm 15570 Pw 7, 15700, 368, 28, 25%, 7.3 V,
FuelRamp T=374C Rpm 15710 Pw 7, 15900, 372, 28, 25%, 7.3 V,
FuelRamp T=378C Rpm 15840 Pw 7, 16000, 376, 28, 25%, 7.3 V,
FuelRamp T=381C Rpm 15960 Pw 7, 16100, 380, 28, 25%, 7.3 V,
FuelRamp T=385C Rpm 16100 Pw 7, 16300, 384, 28, 25%, 7.3 V,
FuelRamp T=389C Rpm 16230 Pw 8, 16400, 388, 32, 25%, 7.3 V,
FuelRamp T=392C Rpm 16370 Pw 8, 16500, 392, 32, 25%, 7.3 V,
FuelRamp T=396C Rpm 16510 Pw 8, 16700, 396, 32, 25%, 7.3 V,
FuelRamp T=400C Rpm 16660 Pw 8, 16800, 400, 32, 25%, 7.3 V,
FuelRamp T=404C Rpm 16800 Pw 8, 17000, 404, 32, 25%, 7.3 V,
FuelRamp T=408C Rpm 16950 Pw 8, 17100, 408, 32, 25%, 7.3 V,
FuelRamp T=412C Rpm 17120 Pw 8, 17300, 412, 32, 25%, 7.3 V,
FuelRamp T=417C Rpm 17290 Pw 8, 17500, 416, 32, 25%, 7.3 V,
FuelRamp T=421C Rpm 17460 Pw 8, 17700, 420, 32, 25%, 7.3 V,
FuelRamp T=425C Rpm 17640 Pw 8, 17900, 424, 32, 25%, 7.3 V,
FuelRamp T=429C Rpm 17830 Pw 9, 18100, 428, 36, 25%, 7.5 V,
FuelRamp T=432C Rpm 18040 Pw 9, 18300, 432, 36, 25%, 7.3 V,
FuelRamp T=437C Rpm 18260 Pw 9, 18500, 436, 36, 25%, 7.3 V,
FuelRamp T=440C Rpm 18480 Pw 9, 18800, 440, 36, 25%, 7.3 V,
FuelRamp T=444C Rpm 18710 Pw 9, 19000, 444, 36, 25%, 7.5 V,
FuelRamp T=448C Rpm 18930 Pw 9, 19200, 448, 36, 25%, 7.5 V,
FuelRamp T=451C Rpm 19150 Pw 9, 19400, 448, 36, 25%, 7.5 V,
FuelRamp T=457C Rpm 19350 Pw 9, 19600, 456, 36, 25%, 7.5 V,
FuelRamp T=460C Rpm 19530 Pw 9, 19800, 460, 36, 25%, 7.5 V,
FuelRamp T=464C Rpm 19710 Pw 9, 19900, 464, 36, 25%, 7.5 V,
FuelRamp T=468C Rpm 19840 Pw 10, 20000, 468, 56, 25%, 7.5 V,
FuelRamp T=471C Rpm 20030 Pw 10, 20300, 468, 56, 25%, 7.5 V,
FuelRamp T=476C Rpm 20270 Pw 10, 20600, 476, 44, 25%, 7.5 V,
FuelRamp T=481C Rpm 20490 Pw 10, 20800, 480, 44, 25%, 7.5 V,
FuelRamp T=486C Rpm 20710 Pw 10, 21000, 484, 44, 25%, 7.5 V,
FuelRamp T=491C Rpm 20900 Pw 10, 21100, 488, 44, 25%, 7.5 V,
FuelRamp T=496C Rpm 21060 Pw 11, 21300, 496, 44, 25%, 7.5 V,
FuelRamp T=499C Rpm 21190 Pw 11, 21300, 496, 40, 25%, 7.5 V,
FuelRamp T=502C Rpm 21300 Pw 11, 21400, 500, 44, 25%, 7.5 V,
FuelRamp T=504C Rpm 21390 Pw 11, 21500, 504, 40, 25%, 7.5 V,
FuelRamp T=507C Rpm 21450 Pw 11, 21500, 504, 44, 25%, 7.5 V,
FuelRamp T=509C Rpm 21500 Pw 11, 21500, 508, 40, 25%, 7.5 V,
FuelRamp T=511C Rpm 21540 Pw 11, 21600, 508, 40, 25%, 7.5 V,
FuelRamp T=513C Rpm 21590 Pw 11, 21600, 512, 44, 25%, 7.5 V,
FuelRamp T=515C Rpm 21640 Pw 11, 21700, 512, 44, 25%, 7.5 V,
FuelRamp T=517C Rpm 21680 Pw 11, 21700, 516, 44, 25%, 7.5 V,
FuelRamp T=520C Rpm 21740 Pw 11, 21800, 520, 44, 25%, 7.5 V,
FuelRamp T=523C Rpm 21890 Pw 11, 22000, 520, 44, 25%, 7.5 V,
FuelRamp T=525C Rpm 21980 Pw 11, 22100, 524, 44, 25%, 7.5 V,
FuelRamp T=527C Rpm 22080 Pw 11, 22200, 524, 44, 25%, 7.5 V,
FuelRamp T=529C Rpm 22230 Pw 11, 22400, 528, 48, 25%, 7.5 V,
FuelRamp T=531C Rpm 22370 Pw 12, 22500, 528, 48, 25%, 7.6 V,
FuelRamp T=534C Rpm 22540 Pw 12, 22700, 532, 48, 25%, 7.6 V,
FuelRamp T=536C Rpm 22720 Pw 12, 22900, 536, 48, 25%, 7.6 V,
FuelRamp T=539C Rpm 22900 Pw 12, 23100, 536, 48, 25%, 7.6 V,
FuelRamp T=541C Rpm 23120 Pw 12, 23400, 540, 48, 25%, 7.6 V,
FuelRamp T=545C Rpm 23350 Pw 12, 23600, 544, 48, 25%, 7.6 V,
FuelRamp T=548C Rpm 23570 Pw 12, 23900, 548, 48, 25%, 7.6 V,
FuelRamp T=551C Rpm 23810 Pw 13, 24100, 548, 52, 25%, 7.6 V,
FuelRamp T=554C Rpm 24050 Pw 13, 24400, 552, 48, 25%, 7.6 V,
FuelRamp T=557C Rpm 24300 Pw 13, 24600, 556, 52, 25%, 7.6 V,
FuelRamp T=560C Rpm 24570 Pw 13, 24900, 560, 52, 25%, 7.6 V,
FuelRamp T=562C Rpm 24860 Pw 14, 25200, 560, 56, 25%, 7.6 V,
FuelRamp T=565C Rpm 25160 Pw 14, 25600, 564, 52, 25%, 7.6 V,
FuelRamp T=568C Rpm 25480 Pw 14, 25900, 568, 56, 25%, 7.6 V,
FuelRamp T=570C Rpm 25820 Pw 14, 26300, 568, 60, 25%, 7.6 V,
FuelRamp T=572C Rpm 26190 Pw 14, 26700, 572, 60, 25%, 7.6 V,
FuelRamp T=574C Rpm 26580 Pw 15, 27100, 572, 60, 25%, 7.6 V,
FuelRamp T=577C Rpm 26980 Pw 15, 27500, 576, 60, 25%, 7.6 V,
FuelRamp T=579C Rpm 27430 Pw 16, 28000, 576, 60, 25%, 7.6 V,
FuelRamp T=581C Rpm 27900 Pw 16, 28600, 580, 64, 25%, 7.6 V,
FuelRamp T=585C Rpm 28420 Pw 16, 29200, 584, 64, 25%, 7.6 V,
FuelRamp T=588C Rpm 29000 Pw 16, 29800, 588, 68, 25%, 7.6 V,
FuelRamp T=594C Rpm 29630 Pw 17, 30500, 592, 68, 25%, 7.6 V,
FuelRamp T=600C Rpm 31360 Pw 18, 31300, 600, 72, 25%, 7.6 V,
FuelRamp T=617C Rpm 33120 Pw 18, 33100, 616, 68, 25%, 7.6 V,
FuelRamp T=625C Rpm 34030 Pw 18, 34000, 624, 68, 25%, 7.6 V,
FuelRamp T=630C Rpm 34960 Pw 18, 34900, 628, 72, 25%, 7.8 V,
Run-Idle T=634C Rpm 35870 Pw 18, 35800, 632, 76, 25%, 7.6 V,
Run-Idle T=636C Rpm 36790 Pw 18, 36700, 636, 72, 25%, 7.8 V,
Run-Idle T=637C Rpm 37610 Pw 18, 37600, 636, 72, 25%, 7.8 V,
Run-Idle T=637C Rpm 38390 Pw 18, 38300, 636, 72, 25%, 7.8 V,
Run-Idle T=634C Rpm 39080 Pw 18, 39000, 632, 72, 25%, 7.8 V,
Run-Idle T=632C Rpm 39590 Pw 18, 39500, 632, 72, 25%, 7.8 V,
Run-Idle T=628C Rpm 39980 Pw 18, 39900, 628, 72, 25%, 7.8 V,
Run-Idle T=623C Rpm 40240 Pw 17, 40200, 620, 72, 25%, 7.8 V,
Run-Idle T=618C Rpm 40370 Pw 17, 40300, 616, 68, 25%, 7.8 V,
Run-Idle T=613C Rpm 40140 Pw 17, 40400, 612, 68, 25%, 7.8 V,
Run-Idle T=607C Rpm 40270 Pw 17, 40400, 604, 68, 25%, 7.8 V,
Run-Idle T=603C Rpm 40320 Pw 17, 40400, 600, 68, 25%, 7.8 V,
Run-Idle T=598C Rpm 40310 Pw 17, 40200, 596, 68, 25%, 7.8 V,
Run-Idle T=593C Rpm 40230 Pw 17, 40100, 592, 68, 25%, 7.8 V,
Run-Idle T=588C Rpm 40100 Pw 17, 39900, 588, 68, 25%, 7.8 V,
Run-Idle T=584C Rpm 39930 Pw 17, 39600, 584, 68, 25%, 7.8 V,
Run-Idle T=581C Rpm 39740 Pw 17, 39400, 580, 68, 25%, 7.8 V,
Run-Idle T=577C Rpm 39540 Pw 17, 39200, 576, 68, 25%, 7.8 V,
Run-Idle T=574C Rpm 39320 Pw 17, 38900, 572, 68, 25%, 7.8 V,
Run-Idle T=573C Rpm 39100 Pw 17, 38700, 572, 64, 25%, 7.8 V,
Run-Idle T=571C Rpm 38870 Pw 16, 38500, 568, 64, 25%, 7.8 V,
Run-Idle T=568C Rpm 38650 Pw 16, 38300, 568, 68, 25%, 7.8 V,
Run-Idle T=567C Rpm 38430 Pw 16, 38100, 564, 68, 25%, 7.8 V,
Run-Idle T=566C Rpm 38210 Pw 16, 37900, 564, 64, 25%, 7.8 V,
Run-Idle T=565C Rpm 38000 Pw 16, 37600, 564, 64, 25%, 7.8 V,
Running T=564C Rpm 37470 Pw 17, 37400, 564, 68, 59%, 7.8 V,
Run-Max T=564C Rpm 37420 Pw 18, 37400, 564, 72, 100%, 7.8 V,
Run-Max T=564C Rpm 37580 Pw 19, 37500, 564, 72, 100%, 7.8 V,
Run-Max T=565C Rpm 37930 Pw 20, 37900, 564, 80, 100%, 7.8 V,
Run-Max T=568C Rpm 38580 Pw 21, 38500, 568, 84, 100%, 7.8 V,
Run-Max T=572C Rpm 39390 Pw 22, 39300, 572, 84, 100%, 7.8 V,
Run-Max T=578C Rpm 40490 Pw 23, 40400, 576, 88, 100%, 7.8 V,
Run-Max T=583C Rpm 41690 Pw 24, 41600, 580, 96, 100%, 7.8 V,
Run-Max T=590C Rpm 43220 Pw 24, 43200, 588, 96, 100%, 7.8 V,
Run-Max T=597C Rpm 44940 Pw 25, 44900, 596, 100, 100%, 7.8 V,
Run-Max T=603C Rpm 46770 Pw 26, 46700, 600, 108, 100%, 7.8 V,
Run-Max T=608C Rpm 48800 Pw 27, 48800, 608, 108, 100%, 7.8 V,
Run-Max T=612C Rpm 50860 Pw 28, 50800, 612, 112, 100%, 7.8 V,
Run-Max T=615C Rpm 53000 Pw 29, 53000, 612, 116, 100%, 7.8 V,
Run-Max T=617C Rpm 55050 Pw 30, 55000, 616, 120, 100%, 7.8 V,
Run-Max T=617C Rpm 57070 Pw 31, 57000, 616, 124, 100%, 7.8 V,
Run-Max T=615C Rpm 59190 Pw 32, 59100, 612, 124, 100%, 7.8 V,
Run-Max T=613C Rpm 61270 Pw 33, 61200, 612, 128, 100%, 7.8 V,
Run-Max T=609C Rpm 63170 Pw 34, 63100, 608, 132, 100%, 7.8 V,
Run-Max T=606C Rpm 65030 Pw 34, 65000, 604, 140, 100%, 7.8 V,
Run-Max T=600C Rpm 66740 Pw 35, 66700, 600, 140, 100%, 7.8 V,
Run-Max T=595C Rpm 68600 Pw 38, 68600, 592, 148, 100%, 7.8 V,
Run-Max T=589C Rpm 70820 Pw 41, 70800, 588, 160, 100%, 7.8 V,
Run-Max T=584C Rpm 73570 Pw 43, 73500, 584, 172, 100%, 7.8 V,
Run-Max T=580C Rpm 76630 Pw 46, 76600, 580, 180, 100%, 7.8 V,
Run-Max T=577C Rpm 80200 Pw 49, 80200, 576, 196, 100%, 7.8 V,
Run-Max T=575C Rpm 84490 Pw 53, 84400, 572, 212, 100%, 7.8 V,
Run-Max T=574C Rpm 89420 Pw 57, 89400, 572, 224, 100%, 7.8 V,
Run-Max T=573C Rpm 94730 Pw 61, 94700, 572, 240, 100%, 7.8 V,
Run-Max T=572C Rpm100200 Pw 67,100200, 572, 264, 100%, 7.8 V,
Run-Max T=571C Rpm106750 Pw 75,106700, 568, 300, 100%, 7.8 V,
Run-Max T=571C Rpm114160 Pw 91,114100, 568, 360, 100%, 7.6 V,
Run-Max T=575C Rpm122430 Pw 98,122400, 572, 388, 100%, 7.6 V,
Run-Max T=584C Rpm127390 Pw102,127300, 584, 404, 100%, 7.6 V,
Run-Max T=597C Rpm129490 Pw103,129400, 596, 412, 100%, 7.6 V,
Run-Max T=610C Rpm129940 Pw103,129900, 608, 412, 100%, 7.6 V,
Run-Max T=621C Rpm130110 Pw103,130100, 620, 412, 100%, 7.6 V,
Run-Max T=631C Rpm130190 Pw102,130100, 628, 408, 100%, 7.6 V,
Run-Max T=639C Rpm130190 Pw102,130100, 636, 408, 100%, 7.6 V,
Run-Max T=644C Rpm129310 Pw102,130200, 644, 408, 100%, 7.6 V,
Run-Max T=648C Rpm129620 Pw102,130100, 648, 408, 100%, 7.6 V,
Run-Max T=652C Rpm129840 Pw102,130200, 652, 408, 100%, 7.6 V,
Run-Max T=654C Rpm129970 Pw102,130200, 652, 408, 100%, 7.6 V,
Run-Max T=658C Rpm130080 Pw101,130200, 656, 404, 100%, 7.6 V,
Run-Max T=660C Rpm130070 Pw101,130000, 660, 408, 100%, 7.6 V,
Run-Max T=663C Rpm130120 Pw101,130200, 660, 404, 100%, 7.6 V,
Running T=665C Rpm130180 Pw 99,130100, 664, 400, 93%, 7.6 V,
Run-Idle T=666C Rpm128660 Pw 73,128600, 664, 312, 25%, 7.8 V,
Run-Idle T=666C Rpm111890 Pw 25,111800, 664, 128, 25%, 7.8 V,
Run-Idle T=651C Rpm 87820 Pw 18, 87800, 648, 80, 25%, 7.8 V,
Run-Idle T=621C Rpm 72500 Pw 16, 72500, 620, 68, 25%, 7.8 V,
Run-Idle T=589C Rpm 62790 Pw 16, 62700, 588, 68, 25%, 7.8 V,
Run-Idle T=561C Rpm 56150 Pw 16, 56100, 560, 64, 25%, 7.8 V,
Run-Idle T=539C Rpm 51540 Pw 16, 51500, 536, 64, 25%, 7.8 V,
Run-Idle T=526C Rpm 48080 Pw 15, 48000, 524, 64, 25%, 7.8 V,
Run-Idle T=516C Rpm 45410 Pw 15, 45400, 516, 64, 25%, 7.8 V,
Run-Idle T=512C Rpm 43280 Pw 15, 43200, 512, 60, 25%, 7.8 V,
Run-Idle T=510C Rpm 41560 Pw 15, 41500, 508, 60, 25%, 7.8 V,
Run-Idle T=511C Rpm 40140 Pw 15, 40100, 508, 60, 25%, 7.8 V,
Run-Idle T=514C Rpm 38950 Pw 15, 38900, 512, 60, 25%, 7.8 V,
Run-Idle T=516C Rpm 37970 Pw 15, 37900, 516, 60, 25%, 7.8 V,
Run-Idle T=520C Rpm 37130 Pw 15, 37100, 520, 56, 25%, 7.8 V,
Run-Idle T=523C Rpm 36410 Pw 15, 36400, 520, 60, 25%, 7.8 V,
Run-Idle T=528C Rpm 35790 Pw 15, 35700, 528, 56, 25%, 7.8 V,
Run-Idle T=535C Rpm 34820 Pw 15, 34800, 532, 60, 25%, 7.8 V,
Run-Idle T=539C Rpm 34470 Pw 15, 34400, 536, 64, 25%, 7.8 V,
Run-Idle T=542C Rpm 34220 Pw 15, 34200, 540, 64, 25%, 7.8 V,
Run-Idle T=546C Rpm 34070 Pw 16, 34000, 544, 64, 25%, 7.8 V,
Run-Idle T=550C Rpm 34040 Pw 16, 34000, 548, 64, 25%, 7.8 V,
Run-Idle T=554C Rpm 34100 Pw 16, 34100, 552, 64, 25%, 7.8 V,
Run-Idle T=558C Rpm 34200 Pw 16, 34200, 556, 64, 25%, 7.8 V,
Run-Idle T=562C Rpm 34310 Pw 16, 34300, 560, 68, 25%, 7.8 V,
Run-Idle T=567C Rpm 34460 Pw 16, 34400, 564, 64, 25%, 7.8 V,
Run-Idle T=570C Rpm 34620 Pw 17, 34600, 568, 64, 25%, 7.8 V,
Run-Idle T=574C Rpm 34760 Pw 17, 34700, 572, 68, 25%, 7.8 V,
Run-Idle T=575C Rpm 34720 Pw 17, 34900, 572, 68, 25%, 7.8 V,
Run-Idle T=578C Rpm 34870 Pw 17, 35000, 576, 64, 25%, 7.8 V,
Run-Idle T=580C Rpm 35250 Pw 17, 35200, 580, 68, 25%, 7.8 V,
Run-Idle T=581C Rpm 35410 Pw 17, 35400, 580, 64, 25%, 7.8 V,
Run-Idle T=581C Rpm 35540 Pw 17, 35500, 580, 64, 25%, 7.8 V,
Running T=582C Rpm 35690 Pw 17, 35600, 580, 68, 28%, 7.8 V,
Running T=583C Rpm 35920 Pw 18, 35900, 580, 72, 34%, 7.8 V,
Running T=584C Rpm 36360 Pw 19, 36300, 584, 76, 34%, 7.8 V,
Run-Idle T=586C Rpm 37010 Pw 19, 37000, 584, 76, 25%, 7.8 V,
Run-Idle T=587C Rpm 37640 Pw 19, 37600, 584, 76, 25%, 7.8 V,
Run-Idle T=590C Rpm 38270 Pw 19, 38200, 588, 76, 25%, 7.8 V,
Run-Idle T=593C Rpm 38860 Pw 19, 38800, 592, 76, 25%, 7.8 V,
Run-Idle T=594C Rpm 39290 Pw 18, 39200, 592, 72, 25%, 7.8 V,
Run-Idle T=595C Rpm 39590 Pw 18, 39500, 592, 72, 25%, 7.8 V,
Run-Idle T=594C Rpm 39720 Pw 17, 39700, 592, 72, 25%, 7.8 V,
Run-Idle T=593C Rpm 39690 Pw 17, 39600, 592, 68, 25%, 7.8 V,
Run-Idle T=590C Rpm 39620 Pw 17, 39600, 588, 72, 25%, 7.8 V,
Run-Idle T=587C Rpm 39500 Pw 17, 39500, 584, 72, 25%, 7.8 V,
Run-Idle T=584C Rpm 39310 Pw 17, 39300, 584, 68, 25%, 7.8 V,
Run-Idle T=581C Rpm 39300 Pw 17, 39100, 580, 72, 25%, 7.8 V,
Run-Idle T=579C Rpm 39150 Pw 17, 38900, 576, 68, 25%, 7.8 V,
Run-Idle T=576C Rpm 38990 Pw 17, 38700, 576, 68, 25%, 7.8 V,
Run-Idle T=572C Rpm 38380 Pw 17, 38300, 572, 68, 25%, 7.8 V,
Running T=570C Rpm 38280 Pw 18, 38200, 568, 72, 60%, 7.8 V,
Run-Max T=570C Rpm 38430 Pw 19, 38400, 568, 76, 100%, 7.8 V,
Run-Max T=570C Rpm 38780 Pw 20, 38700, 568, 80, 100%, 7.8 V,
Run-Max T=572C Rpm 39400 Pw 21, 39400, 572, 84, 100%, 7.8 V,
Run-Max T=575C Rpm 40210 Pw 22, 40200, 572, 88, 100%, 7.8 V,
Run-Max T=579C Rpm 41210 Pw 23, 41200, 576, 92, 100%, 7.8 V,
Run-Max T=583C Rpm 42430 Pw 24, 42400, 580, 96, 100%, 7.8 V,
Run-Max T=587C Rpm 43860 Pw 25, 43800, 584, 96, 100%, 7.8 V,
Run-Max T=592C Rpm 45480 Pw 26, 45400, 592, 104, 100%, 7.8 V,
Run-Max T=596C Rpm 47230 Pw 27, 47200, 596, 108, 100%, 7.8 V,
Run-Max T=599C Rpm 49070 Pw 28, 49000, 596, 112, 100%, 7.8 V,
Run-Max T=600C Rpm 51040 Pw 28, 51000, 600, 112, 100%, 7.8 V,
Run-Max T=602C Rpm 53020 Pw 29, 53000, 600, 116, 100%, 7.8 V,
Run-Max T=603C Rpm 54980 Pw 30, 54900, 600, 120, 100%, 7.8 V,
Run-Max T=603C Rpm 56960 Pw 31, 56900, 600, 124, 100%, 7.8 V,
Run-Max T=602C Rpm 58950 Pw 32, 58900, 600, 128, 100%, 7.8 V,
Run-Max T=601C Rpm 60960 Pw 33, 60900, 600, 132, 100%, 7.8 V,
Run-Max T=599C Rpm 62930 Pw 34, 62900, 596, 136, 100%, 7.8 V,
Run-Max T=595C Rpm 64760 Pw 35, 64700, 592, 140, 100%, 7.8 V,
Run-Max T=593C Rpm 66470 Pw 36, 66400, 592, 144, 100%, 7.8 V,
Run-Max T=588C Rpm 68240 Pw 38, 68200, 588, 152, 100%, 7.8 V,
Run-Max T=583C Rpm 70310 Pw 41, 70300, 580, 160, 100%, 7.8 V,
Run-Max T=580C Rpm 72970 Pw 43, 72900, 580, 172, 100%, 7.8 V,
Run-Max T=575C Rpm 75830 Pw 46, 75800, 572, 184, 100%, 7.8 V,
Run-Max T=573C Rpm 79230 Pw 49, 79200, 572, 192, 100%, 7.8 V,
Run-Max T=570C Rpm 83120 Pw 53, 83100, 568, 208, 100%, 7.8 V,
Run-Max T=569C Rpm 87570 Pw 57, 87500, 568, 224, 100%, 7.8 V,
Run-Max T=569C Rpm 92360 Pw 61, 92300, 568, 240, 100%, 7.8 V,
Run-Max T=569C Rpm 97670 Pw 65, 97600, 568, 256, 100%, 7.8 V,
Run-Max T=570C Rpm103430 Pw 74,103400, 568, 292, 100%, 7.8 V,
Run-Max T=572C Rpm109750 Pw 82,109700, 572, 324, 100%, 7.8 V,
Run-Max T=576C Rpm117850 Pw 96,117800, 576, 380, 100%, 7.8 V,
Run-Max T=582C Rpm124740 Pw 99,124700, 580, 396, 100%, 7.8 V,
Run-Max T=593C Rpm128310 Pw103,128300, 592, 412, 100%, 7.8 V,
Run-Max T=605C Rpm129700 Pw103,129700, 604, 412, 100%, 7.8 V,
Run-Max T=618C Rpm130100 Pw103,130100, 616, 412, 100%, 7.8 V,
Run-Max T=628C Rpm130120 Pw103,130100, 628, 412, 100%, 7.6 V,
Run-Max T=638C Rpm130140 Pw103,130100, 636, 412, 100%, 7.8 V,
Run-Max T=645C Rpm130210 Pw103,130200, 644, 408, 100%, 7.8 V,
Run-Max T=651C Rpm129450 Pw102,130200, 648, 412, 100%, 7.6 V,
Run-Max T=654C Rpm129740 Pw102,130200, 652, 408, 100%, 7.8 V,
Run-Max T=659C Rpm129940 Pw102,130200, 656, 408, 100%, 7.8 V,
Run-Max T=661C Rpm130050 Pw102,130200, 660, 408, 100%, 7.6 V,
Run-Max T=664C Rpm130130 Pw102,130200, 664, 408, 100%, 7.8 V,
Run-Max T=666C Rpm130150 Pw102,130100, 664, 408, 100%, 7.6 V,
Run-Max T=668C Rpm130150 Pw101,130100, 668, 404, 100%, 7.6 V,
Run-Max T=671C Rpm130160 Pw101,130100, 668, 404, 100%, 7.6 V,
Run-Max T=672C Rpm130170 Pw101,130100, 672, 404, 100%, 7.8 V,
Run-Max T=673C Rpm130190 Pw101,130200, 672, 404, 100%, 7.6 V,
Run-Max T=676C Rpm130240 Pw101,130300, 676, 404, 100%, 7.6 V,
Run-Max T=678C Rpm130260 Pw101,130300, 676, 404, 100%, 7.6 V,
Run-Max T=679C Rpm130290 Pw101,130300, 676, 404, 100%, 7.8 V,
Run-Max T=681C Rpm130290 Pw101,130300, 680, 404, 100%, 7.8 V,
Run-Max T=683C Rpm130280 Pw101,130200, 680, 404, 100%, 7.8 V,
Run-Max T=684C Rpm130270 Pw101,130200, 684, 404, 100%, 7.6 V,
Run-Max T=685C Rpm130260 Pw101,130200, 684, 404, 100%, 7.8 V,
Run-Max T=687C Rpm130250 Pw101,130200, 684, 404, 100%, 7.8 V,
Run-Max T=688C Rpm130260 Pw101,130200, 688, 404, 100%, 7.8 V,
Run-Max T=690C Rpm130280 Pw101,130300, 688, 404, 100%, 7.8 V,
Running T=691C Rpm130280 Pw100,130200, 688, 400, 88%, 7.8 V,
Run-Idle T=692C Rpm128370 Pw 68,128300, 692, 296, 25%, 7.8 V,
Run-Idle T=689C Rpm109960 Pw 24,109900, 688, 116, 25%, 7.8 V,
Run-Idle T=673C Rpm 86900 Pw 18, 86900, 672, 80, 25%, 7.8 V,
Run-Idle T=642C Rpm 72190 Pw 16, 72100, 640, 68, 25%, 7.8 V,
Run-Idle T=610C Rpm 62610 Pw 15, 62600, 608, 64, 25%, 7.8 V,
Run-Idle T=582C Rpm 56040 Pw 15, 56000, 580, 60, 25%, 7.8 V,
Run-Idle T=561C Rpm 51180 Pw 15, 51100, 560, 60, 25%, 7.8 V,
Run-Idle T=547C Rpm 47600 Pw 15, 47600, 544, 60, 25%, 7.8 V,
Run-Idle T=537C Rpm 44900 Pw 15, 44900, 536, 60, 25%, 7.8 V,
Run-Idle T=533C Rpm 42880 Pw 15, 42800, 532, 60, 25%, 7.8 V,
Run-Idle T=532C Rpm 41160 Pw 15, 41100, 532, 60, 25%, 7.8 V,
Run-Idle T=533C Rpm 39840 Pw 15, 39800, 532, 60, 25%, 7.8 V,
Run-Idle T=535C Rpm 38730 Pw 15, 38700, 532, 56, 25%, 7.8 V,
Run-Idle T=539C Rpm 37800 Pw 15, 37800, 536, 60, 25%, 7.8 V,
Run-Idle T=543C Rpm 37040 Pw 15, 37000, 540, 60, 25%, 7.8 V,
Run-Idle T=547C Rpm 36400 Pw 15, 36400, 544, 60, 25%, 7.8 V,
Run-Idle T=551C Rpm 35850 Pw 15, 35800, 548, 60, 25%, 7.8 V,
Run-Idle T=555C Rpm 35390 Pw 15, 35300, 552, 60, 25%, 7.8 V,
Run-Idle T=560C Rpm 34990 Pw 15, 34900, 560, 64, 25%, 7.8 V,
Run-Idle T=562C Rpm 34670 Pw 15, 34600, 560, 60, 25%, 7.8 V,
Run-Idle T=566C Rpm 34430 Pw 15, 34400, 564, 60, 25%, 7.8 V,
Run-Idle T=568C Rpm 34280 Pw 16, 34200, 568, 64, 25%, 7.8 V,
Run-Idle T=572C Rpm 34240 Pw 16, 34200, 572, 64, 25%, 7.8 V,
Run-Idle T=574C Rpm 34270 Pw 16, 34200, 572, 64, 25%, 7.8 V,
Run-Idle T=579C Rpm 34410 Pw 17, 34400, 576, 68, 25%, 7.8 V,
Run-Idle T=583C Rpm 34570 Pw 17, 34500, 580, 68, 25%, 7.8 V,
Run-Idle T=587C Rpm 34800 Pw 17, 34800, 584, 68, 25%, 7.8 V,
Run-Idle T=590C Rpm 35040 Pw 17, 35000, 588, 68, 25%, 7.8 V,
Run-Idle T=594C Rpm 35270 Pw 17, 35200, 592, 68, 25%, 7.8 V,
Run-Idle T=596C Rpm 35480 Pw 17, 35400, 596, 68, 25%, 7.8 V,
Run-Idle T=598C Rpm 35700 Pw 17, 35700, 596, 68, 25%, 7.8 V,
Run-Idle T=600C Rpm 35900 Pw 17, 35900, 600, 68, 25%, 7.8 V,
Run-Idle T=600C Rpm 36070 Pw 17, 36000, 600, 68, 25%, 7.8 V,
Run-Idle T=601C Rpm 36220 Pw 17, 36200, 600, 68, 25%, 7.8 V,
Run-Idle T=601C Rpm 36350 Pw 17, 36300, 600, 68, 25%, 7.8 V,
Run-Idle T=601C Rpm 36260 Pw 17, 36400, 600, 64, 25%, 7.8 V,
Run-Idle T=600C Rpm 36590 Pw 17, 36500, 600, 64, 25%, 7.8 V,
Run-Idle T=600C Rpm 36670 Pw 17, 36600, 600, 68, 25%, 7.8 V,
Run-Idle T=600C Rpm 36730 Pw 17, 36700, 600, 68, 25%, 7.8 V,
Run-Idle T=599C Rpm 36820 Pw 17, 36800, 596, 68, 25%, 7.8 V,
Run-Idle T=597C Rpm 36870 Pw 17, 36800, 596, 68, 25%, 7.8 V,
Run-Idle T=596C Rpm 36890 Pw 17, 36800, 596, 64, 25%, 7.8 V,
Run-Idle T=595C Rpm 36900 Pw 16, 36900, 592, 64, 25%, 7.8 V,
Run-Idle T=594C Rpm 36890 Pw 16, 36800, 592, 68, 25%, 7.8 V,
Run-Idle T=594C Rpm 36900 Pw 16, 36900, 592, 68, 25%, 7.8 V,
Run-Idle T=593C Rpm 36870 Pw 16, 36800, 592, 64, 25%, 7.8 V,
Run-Idle T=592C Rpm 36840 Pw 16, 36800, 592, 64, 25%, 7.8 V,
Run-Idle T=591C Rpm 36800 Pw 16, 36800, 588, 68, 25%, 7.8 V,
Running T=590C Rpm 36790 Pw 18, 36700, 588, 68, 53%, 7.8 V,
Running T=589C Rpm 37070 Pw 19, 37000, 588, 76, 65%, 7.8 V,
Running T=590C Rpm 37540 Pw 20, 37500, 588, 80, 78%, 7.8 V,
Run-Max T=592C Rpm 38210 Pw 21, 38200, 592, 84, 100%, 7.8 V,
Run-Max T=594C Rpm 39100 Pw 22, 39100, 592, 84, 100%, 7.8 V,
Run-Max T=598C Rpm 40180 Pw 23, 40100, 596, 92, 100%, 7.8 V,
Run-Max T=602C Rpm 41470 Pw 23, 41400, 600, 96, 100%, 7.8 V,
Run-Max T=607C Rpm 42940 Pw 24, 42900, 604, 96, 100%, 7.8 V,
Run-Max T=611C Rpm 44560 Pw 25, 44500, 608, 100, 100%, 7.8 V,
Run-Max T=613C Rpm 46340 Pw 26, 46300, 612, 104, 100%, 7.8 V,
Run-Max T=616C Rpm 48260 Pw 29, 48200, 616, 112, 100%, 7.8 V,
Run-Max T=618C Rpm 50530 Pw 31, 50500, 616, 120, 100%, 7.8 V,
Run-Max T=619C Rpm 52940 Pw 32, 52900, 616, 128, 100%, 7.8 V,
Run-Max T=620C Rpm 55430 Pw 34, 55400, 620, 136, 100%, 7.8 V,
Run-Max T=622C Rpm 58000 Pw 37, 58000, 620, 148, 100%, 7.8 V,
Run-Max T=624C Rpm 60510 Pw 39, 60500, 624, 156, 100%, 7.8 V,
Run-Max T=624C Rpm 62990 Pw 41, 62900, 624, 164, 100%, 7.8 V,
Run-Max T=623C Rpm 65350 Pw 44, 65300, 620, 176, 100%, 7.8 V,
Run-Max T=621C Rpm 66610 Pw 46, 66600, 620, 184, 100%, 7.8 V,
Run-Max T=618C Rpm 66540 Pw 47, 66500, 616, 188, 100%, 7.8 V,
Run-Max T=613C Rpm 65030 Pw 48, 65400, 612, 192, 100%, 7.8 V,
Run-Max T=609C Rpm 64580 Pw 49, 63900, 608, 196, 100%, 7.8 V,
Run-Max T=605C Rpm 61150 Pw 50, 61100, 604, 200, 100%, 7.8 V,
Run-Max T=603C Rpm 57200 Pw 51, 57200, 600, 204, 100%, 7.8 V,
Run-Max T=602C Rpm 52470 Pw 47, 52400, 600, 196, 100%, 7.8 V,
Run-Max T=602C Rpm 49420 Pw 43, 49400, 600, 172, 100%, 7.8 V,
Run-Max T=604C Rpm 47830 Pw 44, 47800, 604, 176, 100%, 7.8 V,
Run-Max T=607C Rpm 45950 Pw 38, 45900, 604, 152, 100%, 7.8 V,
Run-Max T=612C Rpm 46160 Pw 39, 46100, 612, 156, 100%, 7.8 V,
Run-Max T=617C Rpm 46180 Pw 38, 46100, 616, 152, 100%, 7.8 V,
Run-Max T=623C Rpm 47010 Pw 39, 46500, 620, 156, 100%, 7.8 V,
Run-Max T=630C Rpm 46550 Pw 38, 45800, 628, 152, 100%, 7.8 V,
Run-Idle T=636C Rpm 46220 Pw 38, 46200, 636, 152, 25%, 7.8 V,
Run-Idle T=641C Rpm 47000 Pw 37, 47000, 640, 148, 25%, 7.8 V,
Run-Idle T=646C Rpm 47330 Pw 36, 47300, 644, 144, 25%, 7.8 V,
Run-Idle T=650C Rpm 48770 Pw 35, 48700, 648, 144, 25%, 7.8 V,
Run-Idle T=652C Rpm 49370 Pw 34, 49300, 652, 136, 25%, 7.8 V,
Run-Idle T=653C Rpm 50860 Pw 33, 50800, 652, 132, 25%, 7.8 V,
Run-Idle T=654C Rpm 52640 Pw 31, 52600, 652, 124, 25%, 7.8 V,
Run-Idle T=656C Rpm 54550 Pw 31, 54500, 656, 124, 25%, 7.8 V,
Run-Idle T=655C Rpm 56250 Pw 30, 56200, 652, 120, 25%, 7.8 V,
Run-Idle T=653C Rpm 57940 Pw 30, 57900, 652, 120, 25%, 7.8 V,
Run-Idle T=649C Rpm 59450 Pw 29, 59400, 648, 116, 25%, 7.8 V,
Run-Idle T=643C Rpm 60690 Pw 29, 60600, 640, 116, 25%, 7.8 V,
Run-Idle T=636C Rpm 61500 Pw 28, 61500, 636, 112, 25%, 7.8 V,
Run-Idle T=627C Rpm 61750 Pw 28, 61700, 624, 112, 25%, 7.8 V,
Run-Idle T=619C Rpm 61610 Pw 27, 61600, 616, 108, 25%, 7.8 V,
Run-Idle T=609C Rpm 61080 Pw 27, 61000, 608, 108, 25%, 7.8 V,
Run-Idle T=600C Rpm 60280 Pw 26, 60200, 600, 104, 25%, 7.8 V,
Run-Idle T=591C Rpm 59350 Pw 26, 59300, 588, 104, 25%, 7.8 V,
Run-Idle T=583C Rpm 58300 Pw 25, 58300, 580, 100, 25%, 7.8 V,
Running T=576C Rpm 57200 Pw 25, 57200, 576, 104, 46%, 7.8 V,
Running T=570C Rpm 56460 Pw 28, 56400, 568, 108, 77%, 7.8 V,
Run-Max T=567C Rpm 56620 Pw 30, 56600, 564, 120, 100%, 7.8 V,
Run-Max T=565C Rpm 57490 Pw 32, 57400, 564, 128, 100%, 7.8 V,
Run-Max T=566C Rpm 58850 Pw 34, 58800, 564, 136, 100%, 7.8 V,
Run-Max T=568C Rpm 60600 Pw 36, 60600, 568, 144, 100%, 7.8 V,
Run-Max T=573C Rpm 62510 Pw 39, 62500, 572, 152, 100%, 7.8 V,
Run-Max T=575C Rpm 64670 Pw 41, 64600, 572, 164, 100%, 7.8 V,
Run-Max T=579C Rpm 66670 Pw 43, 66600, 576, 168, 100%, 7.8 V,
Run-Max T=581C Rpm 68320 Pw 48, 68300, 580, 188, 100%, 7.8 V,
Run-Max T=581C Rpm 66770 Pw 50, 66700, 580, 200, 100%, 7.8 V,
Run-Max T=581C Rpm 63760 Pw 50, 63700, 580, 204, 100%, 7.8 V,
Running T=579C Rpm 56550 Pw 51, 56500, 576, 204, 94%, 7.8 V,
Run-Idle T=570C Rpm 43000 Pw 34, 43000, 568, 168, 25%, 7.8 V,
Run-Idle T=550C Rpm 34880 Pw 26, 34800, 548, 108, 25%, 7.8 V,
Run-Idle T=525C Rpm 29310 Pw 27, 29300, 524, 108, 25%, 7.8 V,
Run-Idle T=503C Rpm 25290 Pw 27, 25200, 500, 108, 25%, 7.8 V,
SpeedLow T=483C Rpm 22210 Pw , 22200, 480, 0, 25%, 7.8 V,
Stop T=469C Rpm 19770 Pw , 19700, 468, 0, 10%, 7.8 V,
Stop T=456C Rpm 17850 Pw , 17800, 456, 0, 9%, 7.8 V,
Stop T=447C Rpm 16200 Pw , 16200, 444, 0, 9%, 7.8 V,
Stop T=440C Rpm 14850 Pw , 14800, 440, 0, 9%, 7.8 V,
Stop T=435C Rpm 13690 Pw , 13600, 432, 0, 9%, 7.8 V,
Stop T=430C Rpm 12690 Pw , 12600, 428, 0, 9%, 7.8 V,
Stop T=427C Rpm 11830 Pw , 11800, 424, 0, 9%, 7.8 V,
Stop T=425C Rpm 11090 Pw , 11000, 424, 0, 9%, 7.8 V,
Stop T=488C Rpm 10410 Pw , 10400, 488, 0, 9%, 7.8 V,
Stop T=487C Rpm 9820 Pw , 9800, 484, 0, 9%, 7.8 V,
Stop T=485C Rpm 9290 Pw , 9200, 484, 0, 9%, 7.8 V,
Stop T=484C Rpm 8810 Pw , 8800, 484, 0, 9%, 7.8 V,
Stop T=483C Rpm 8360 Pw , 8300, 480, 0, 9%, 7.8 V,
Stop T=481C Rpm 7970 Pw , 7900, 480, 0, 9%, 7.8 V,
Stop T=481C Rpm 7610 Pw , 7600, 480, 0, 9%, 7.8 V,
Stop T=480C Rpm 7280 Pw , 7200, 480, 0, 9%, 7.8 V,
Stop T=479C Rpm 6970 Pw , 6900, 476, 0, 9%, 7.8 V,
Stop T=478C Rpm 6680 Pw , 6600, 476, 0, 9%, 7.8 V,
Stop T=477C Rpm 6420 Pw , 6400, 476, 0, 9%, 7.8 V,
Stop T=476C Rpm 6160 Pw , 6100, 476, 0, 9%, 7.8 V,
Stop T=474C Rpm 5940 Pw , 5900, 472, 0, 9%, 7.8 V,
Stop T=473C Rpm 5720 Pw , 5700, 472, 0, 9%, 7.8 V,
Stop T=472C Rpm 5510 Pw , 5500, 472, 0, 9%, 7.8 V,
Stop T=471C Rpm 5330 Pw , 5300, 468, 0, 9%, 7.8 V,
Stop T=470C Rpm 5160 Pw , 5100, 468, 0, 9%, 7.8 V,
Stop T=469C Rpm 4980 Pw , 4900, 468, 0, 9%, 7.8 V,
Stop T=466C Rpm 4670 Pw , 4600, 464, 0, 9%, 7.8 V,
Stop T=465C Rpm 4540 Pw , 4500, 464, 0, 9%, 7.8 V,
Stop T=464C Rpm 4400 Pw , 4400, 464, 0, 9%, 7.8 V,
Stop T=463C Rpm 4270 Pw , 4200, 460, 0, 9%, 7.8 V,
Stop T=462C Rpm 4150 Pw , 4100, 460, 0, 9%, 7.8 V,
Stop T=461C Rpm 4030 Pw , 4000, 460, 0, 9%, 7.8 V,
Stop T=460C Rpm 3920 Pw , 3900, 460, 0, 9%, 7.8 V,
Stop T=458C Rpm 3810 Pw , 3800, 456, 0, 9%, 7.8 V,
Stop T=457C Rpm 3710 Pw , 3700, 456, 0, 9%, 7.8 V,
Stop T=456C Rpm 3620 Pw , 3600, 456, 0, 9%, 7.8 V,
Stop T=455C Rpm 3520 Pw , 3500, 452, 0, 9%, 7.8 V,
Stop T=454C Rpm 3430 Pw , 3400, 452, 0, 9%, 7.8 V,
Stop T=453C Rpm 3340 Pw , 3300, 452, 0, 9%, 7.8 V,
Stop T=452C Rpm 3250 Pw , 3200, 452, 0, 9%, 7.8 V,
Stop T=451C Rpm 3180 Pw , 3100, 448, 0, 9%, 7.8 V,
Stop T=450C Rpm 3100 Pw , 3100, 448, 0, 9%, 7.8 V,
Stop T=449C Rpm 3030 Pw , 3000, 448, 0, 9%, 7.8 V,
Stop T=448C Rpm 2980 Pw , 2900, 448, 0, 9%, 7.8 V,
Stop T=447C Rpm 3240 Pw , 3200, 444, 0, 9%, 7.8 V,
Stop T=446C Rpm 3620 Pw , 3600, 444, 0, 9%, 7.8 V,
Stop T=444C Rpm 3940 Pw , 3900, 444, 0, 9%, 7.8 V,
Stop T=442C Rpm 4250 Pw , 4200, 440, 0, 9%, 7.8 V,
Stop T=440C Rpm 4530 Pw , 4500, 440, 0, 9%, 7.8 V,
Stop T=438C Rpm 4770 Pw , 4700, 436, 0, 9%, 7.8 V,
Stop T=436C Rpm 5000 Pw , 5000, 436, 0, 9%, 7.8 V,
Stop T=434C Rpm 5200 Pw , 5200, 432, 0, 9%, 7.8 V,
Stop T=431C Rpm 5380 Pw , 5300, 428, 0, 9%, 7.8 V,
Cooling T=429C Rpm 5540 Pw , 5500, 428, 0, 9%, 7.8 V,
Cooling T=427C Rpm 5670 Pw , 5600, 424, 0, 9%, 7.8 V,
Cooling T=424C Rpm 5760 Pw , 5700, 424, 0, 9%, 7.8 V,
Cooling T=421C Rpm 5810 Pw , 5800, 420, 0, 9%, 7.8 V,
Cooling T=419C Rpm 5830 Pw , 5800, 416, 0, 9%, 7.8 V,
Cooling T=416C Rpm 5820 Pw , 5800, 416, 0, 9%, 7.8 V,
Cooling T=414C Rpm 5780 Pw , 5700, 412, 0, 9%, 7.8 V,
Cooling T=412C Rpm 5730 Pw , 5700, 412, 0, 9%, 7.8 V,
Cooling T=409C Rpm 5670 Pw , 5600, 408, 0, 9%, 7.8 V,
Cooling T=407C Rpm 5610 Pw , 5600, 404, 0, 9%, 7.8 V,
Cooling T=405C Rpm 5540 Pw , 5500, 404, 0, 9%, 7.8 V,
Cooling T=403C Rpm 5470 Pw , 5400, 400, 0, 9%, 7.8 V,
Cooling T=401C Rpm 5400 Pw , 5400, 400, 0, 9%, 7.8 V,
Cooling T=399C Rpm 5330 Pw , 5300, 396, 0, 9%, 7.8 V,
Cooling T=397C Rpm 5260 Pw , 5200, 396, 0, 9%, 7.8 V,
Cooling T=395C Rpm 5200 Pw , 5200, 392, 0, 9%, 7.8 V,
Cooling T=393C Rpm 5140 Pw , 5100, 392, 0, 9%, 7.8 V,
Cooling T=391C Rpm 5090 Pw , 5000, 388, 0, 9%, 7.8 V,
Cooling T=390C Rpm 5040 Pw , 5000, 388, 0, 9%, 7.8 V,
Cooling T=388C Rpm 4990 Pw , 4900, 388, 0, 9%, 7.8 V,
Cooling T=387C Rpm 4950 Pw , 4900, 384, 0, 9%, 7.8 V,
Cooling T=385C Rpm 4920 Pw , 4900, 384, 0, 9%, 7.8 V,
Cooling T=384C Rpm 4890 Pw , 4800, 384, 0, 9%, 7.8 V,
Cooling T=382C Rpm 4870 Pw , 4800, 380, 0, 9%, 7.8 V,
Cooling T=380C Rpm 4850 Pw , 4800, 380, 0, 9%, 7.8 V,
Cooling T=379C Rpm 4840 Pw , 4800, 376, 0, 9%, 7.8 V,
Cooling T=377C Rpm 4830 Pw , 4800, 376, 0, 9%, 7.8 V,
Cooling T=376C Rpm 4830 Pw , 4800, 376, 0, 9%, 7.8 V,
Cooling T=375C Rpm 4830 Pw , 4800, 372, 0, 9%, 7.8 V,
Cooling T=373C Rpm 4840 Pw , 4800, 372, 0, 9%, 7.8 V,
Cooling T=372C Rpm 4840 Pw , 4800, 372, 0, 9%, 7.8 V,
Cooling T=370C Rpm 4850 Pw , 4800, 368, 0, 9%, 7.8 V,
Cooling T=369C Rpm 4860 Pw , 4800, 368, 0, 9%, 7.8 V,
Cooling T=368C Rpm 4880 Pw , 4800, 368, 0, 9%, 7.8 V,
Cooling T=366C Rpm 4890 Pw , 4800, 364, 0, 9%, 7.8 V,
Cooling T=365C Rpm 4900 Pw , 4900, 364, 0, 9%, 7.8 V,
Cooling T=363C Rpm 4910 Pw , 4900, 360, 0, 9%, 7.8 V,
Cooling T=362C Rpm 4920 Pw , 4900, 360, 0, 9%, 7.8 V,
Cooling T=360C Rpm 4940 Pw , 4900, 360, 0, 9%, 7.8 V,
Cooling T=359C Rpm 4950 Pw , 4900, 356, 0, 9%, 7.8 V,
Cooling T=357C Rpm 4960 Pw , 4900, 356, 0, 9%, 7.8 V,
Cooling T=356C Rpm 4970 Pw , 4900, 356, 0, 9%, 7.8 V,
Cooling T=354C Rpm 4980 Pw , 4900, 352, 0, 9%, 7.8 V,
Cooling T=353C Rpm 4980 Pw , 4900, 352, 0, 9%, 7.8 V,
Cooling T=351C Rpm 4990 Pw , 4900, 348, 0, 9%, 7.8 V,
Cooling T=350C Rpm 4990 Pw , 4900, 348, 0, 9%, 7.8 V,
Any ideas?
