RE: HELP! Hoobico MKII ok for Lithium Poly's?
Dick, are you getting a full 12.6 volts into the cells from this charger when it completes its charge cycle?
The Triton we were playing around with often stopped the cycle at 90% capacity. Most times at 12.1 volts or less. Be interesting to see if the Hobbico got the full 12.6 into the cells. If its does, thats quite the bargain charger, and multi use as well.
GW.
