Originally Posted by
Zeeb
I just have the trim travel set to max per click, so it only takes a couple of clicks to move it from one end to the other, works great.
I may be suspicious but as an old guy, I want my radio setup to be as nearly identical on all models and all the tx's. I have one turbine on a JR 12X and I understand why guys liked the analog trim. The others are presently on the 18MZ, but the next one will go on the 18SZ because it fits my hands better.
Also, and this may be the biggest concern for me; what if someone else needs to shut down the turbine? Every turbine driver I know, uses the throttle trim to start/run/shut down.
Good points Zeeb. Two other reasons I don't use a switch to shut down the turbine: Frequently not having a convenient spare switch and the possibility of bumping it off accidentally if I did. The 3 step digital trim works for me too.
Craig
