Old 07-12-2017, 10:13 PM
  #59
roger.alli
roger.alli's Avatar
You'd be right Matt. SByrd says he has a Classic Bandit, which has a slimmer fuse than the SB. He will need these tanks.. Classic Bandit Kevlar Fuel Cells [BVM6080] - $355.00 : ShopBVMJets.com, your one stop jet shop! The SB has more fuel on board than the Classic. It was probably the main reason for the redesign. .
The current BVM Bypasses fit any of the Bandits, so you just need to get the right one for your engine, although an inlet adapter may be required as well.
And I will bet that BVM can also supply a tail cone for a Classic.. They are good with obsolete parts, if a little pricey..
Roger
