Originally Posted by
All Day Dan
This is all guess work. First, don't run the engine without the wing attached. Rebuild the carburetor. Change the ignition module. See if CH ignitions has one for you. It looks like you got a winner there. Keep us posted
I posted this on Flying Giants also, and one guy immediately spotted the problem. Many ignition units use 4.8v-6v packs in the past. The guy who read my post on Flying Giants noticed that I had a 4.8v pack on ignition, and immediately recognized it as my problem. I went to the Aircraft International site, and sure enough it says to use 6v-8v for ignition. I installed a 6.6v LiFe pack, and it solved the problem it seems.
Now, I do have a question for you... Why do you say not to run the engine without the wing? I realize that the canopy does add strength and support, but I don't think the wing does. Do you say this maybe for vibration dampening? Just a guess. I've been flying for more than 30 years, but I am still a bit green when it comes to 100cc and up. This is my second one in that range. Thanks for the help!
