The Sebart Angel S EVO 50e might be long out of production but I found one, new in the box, for a great price. I am hoping it will be a good tool to use to get back into pattern after around 20 years. The kit was complete other than the spinner and wing mounting bolts, since the bolts are 4mm they were easy to find.
The plane is equipped with an OS 5025-375 motor running on 6S 5000mah packs swinging a 16x10E APC prop. I am using a Jeti spin 99 ESC. On the ground I can see that I might have to go up one prop size but for now I will fly it the way it is.
As you can see I still need to get a spinner!
Next on the workbench is a Sebart MythoS 50e and then a 125.
Rudi
