[QUOTE=sidgates;12360201]
Originally Posted by
roger.alli
Thanks Raff and Ad. I understand now. Set it up so that in the max brake or park position, the servo arm is in line with the push rod, which effectively unloads the servo.
I love the BVM pneumatic wheel brakes, but their sooth stop valve is just junk. The one in my Hun worked great for a dozen flights, and then one day at a rally it started loosing air, intermittently, with the predictable runway over shoot and busted nose gear rails.
The E brake looks to be such a simple and elegant solution with no on board tanks and no compressor required..
I might do some testing as I have one of the large cylinders to hand.[/Q
I tried this unit several years ago and wasn't successfull, probably my install. If I used it again I would probably put the brake servo on separate battery.
I had the same problem with one and the BVM grease never helped. I used some old kitchen faucet gasket grease I had laying around and never had another leak.
