RCU Forums - View Single Post - Electron retracts problem
Old 09-11-2017 | 02:11 AM
bluelevel's Avatar
bluelevel
My Feedback: (39)
Martin, 60% gain for the nose wheel, heading hold works fine with the PB gyros BUT ONLY if you are using a separate channel. That will only be possible with a PB Royal or a PB distribution box hooked up to an iGyro SRS. If you are using the smaller 3e gyro or the SRS without a Powerbox, you will most likely have the rudder connected to the gyro
