You can also just use a 3mm tubing(retract tubing) in the center hole to fill it with no other connections. Just don't insert too deep for the flapper valve inside. That is all I use. Works well. Be careful to not get any sand or other dirt inside the valve. Won't hold air anymore if you do.
