RCU Forums - View Single Post - Plugging the tank vent line, yes or no?
Old 10-13-2017, 03:48 PM
jetflyr
Originally Posted by AEROSHELDON View Post
Thank you. There seems to be a lot of pressure on the system when I plug them is why I am asking, lots of air either escapes or gets sucked in and it seems that might be unhealthy for the system.
The only time I have seen pressure changes has been going over Raton Pass heading to/from low level. If I take it to the field and it is blowing a gale, but we all sit and BS for awhile, the heat of being in a car in the sun at 7000' will create pressure (more in my gasoline container though). - I then just vent the system before I drive home
If you are getting a lot of air in the system, I'd check the system! it should be tight when sealed.
Greg
