Old 10-13-2017, 06:42 PM
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Originally Posted by jetflyr View Post
The only time I have seen pressure changes has been going over Raton Pass heading to/from low level. If I take it to the field and it is blowing a gale, but we all sit and BS for awhile, the heat of being in a car in the sun at 7000' will create pressure (more in my gasoline container though). - I then just vent the system before I drive home
If you are getting a lot of air in the system, I'd check the system! it should be tight when sealed.
Greg
Thanks... It's tight! The release is when I un-plug it. Temp changes are the biggest culprit. I will just do as you do and occasionally unplug it when I know that is happening.
