Originally Posted by
Auburn02
Has anyone ever benefitted from “protection of the AMA?”
I suppose the only reason I’m a member at all is to fly at fields that require it. But with that said, is there a rule that actually matters in the US with regard to model size? By that I mean something the FAA mandates, since AMA is not a governing body.
The fact that the FAA allows you to fly turbines under the AMA programming is you directly benefiting from "ama protection"
