RCU Forums - View Single Post - Field Toolbox Ideas
Old 10-30-2017 | 07:24 PM
aspeed's Avatar
aspeed
The first toolbox is just over 28 lbs. It isn't bad to walk 30 feet, but going up the stairs, and over to the car, swinging around railings and opening doors, and at some fields it is a couple hundred feet. I have pretty much taken most things out that are not needed. It mostly is the box, and maybe the small 5A. battery. I could just have a light dolly on the first toolbox. I only bring a quart of fuel and don't do major repairs at the field, just plugs and props mostly. The big plastic box is just over 10 lbs empty, I think once I am up the stairs, it will be ok. All the other ones in the pics were a bit short on room for plug wires and the starter. I have a smaller starter now. I hope it works on the bigger motors. .46 and .91 max. I don't need a table, as there are normally enough at the field. I am not really a weak old man, but maybe a bit sore all the time, and puffing a bit when it is hot. I can't be the only one with this problem, I see lots of guys limping around in worse shape than me.
