Thread: Slick sand
Old 11-11-2017, 08:04 AM
Pylonracr
Pylonracr's Avatar
What are you going to make your mold out of? If you plan on using epoxy (Highly recommended) do not use any polyester products in your plug. While it can be done successfully, the usual result is styrene migration from the polyester to the epoxy causing major release problems.
Scott
