RCU Forums - View Single Post - Simulated Hinges
Old 11-12-2017 | 09:07 AM
ziggy138
Default simulated hinges
You can simulate hinges bu using small dia. alum. tubing. Cut into small pieces and run wire thru center. You must glue every other tube to same surface on one side, then glue the other tubes to opposite surface. Do this very carefully and you will have a scale hinge that works also. Just use wire to keep it all lined up, and keep wire lubed also so you do not glue it in place.
