Originally Posted by
JollyPopper
Can NiMH batteries be charged with a charger designed to charge NiCad batteries?
It will charge, but it's not advisable if it's a peak detection rapid charger, the peak detection on NiCd rapid chargers is not sensitive enough for NiMH charging and will not shut off when the battery is full.
If the charger is a 1C Delta-T charger (uses temperature detection for auto cutoff) it will work on NiMH.
