RCU Forums - View Single Post - Old wren help
Thread: Old wren help
Old 11-27-2017, 02:25 PM
ira d
Sounds like its not switching over to Kero after lighting off on gas, could be a weak battery or something not right with the fuel pump or valves. I would use the test mode to test fuel flow to insure pump and valves
are working with no obstructions in any lines, also check to see if the temps are rising after a light on gas. A word caution do not start the engine to much on gas if its not getting kero because that will destroy the bearings.
