Power supply flashing light when running
good morning,
l am total noob in this forum (first post). I have this exact power supply and soldered jumpers 33 and 36 as you showed. My soldering skills are beginner and I believe solder got on the tabs between 33 and 36. Could this be the reason the supply is not working properly and the light on the back keeps flashing. I don’t believe the fan spins up either. If so, is there a way to remove the solder and stop from contacting each other. Please let me know if there is anything I am missing and what I should do to get it going. Special wire, solder, etc? Your original post and build are fantastic. Thank you.
