Mine is essentially a gathering of parts from several sources, with no documentation on what it should have come with. I'm also assembling it in electric and would like to know a few things on your setup. First on canopy. Can you describe or take photos of the canopy hold-down/alignment interfaces to the fuse? Regarding landing gear, I've seen photos indicating it mounts to the inside of second-level fuse floor, which sort of makes sense from a landing gear, but am uncomfortable about battery location, which I suspect is on that same second-level floor. Maybe the battery stuff would fit better if the landing gear is on the belly-pan-side of the second-level.
