RCU Forums - View Single Post - Cockpit kit tools
Old 02-01-2018 | 06:28 AM
carlgrover
Originally Posted by aymodeler
When cutting vacuum formed pieces, I have (after much trial and error) found it best not to try to cut right up to the final edge of the part. Instead, I use scissors, snips, a sharp knife, or whatever is convenient to rough out the shape, leaving a small amount of material which I sand or file away to the final edge.
For larger parts, I will use blue masking tape to mark off the final line, then use a rotary sanding drum in my Dremel to clean up to the line. For smaller parts, I use a bit of sandpaper stuck to a popsicle stick, dowel, or some other suitable "stick". For very tight corners, I use a set of needle files for the final clean-up. If you need a good square edge (e.g.; two halves of a set of wheel pants), lay down a bit of sandpaper on flat surface and carefully slide the part on it (rather than sliding the sandpaper) for 2 or 3 light passes to square up the edge.
I do the same thing. Watch out with the dremel tool though. If you get too happy with it, heat will build up and start to partially melt the plastic. Also, it may leave a stringy edge. I run my fingernail down the edge to keep a clean line.
carl
