RCU Forums - View Single Post - Aurora 9X
Thread: Aurora 9X
Old 02-02-2018, 11:08 AM
Xpress
Xpress's Avatar
There is risk of shorting both the charger and the transmitter out, as well as overcharging the battery and causing a fire. The included charger is an NiMH charger that will charge the stock Tx battery at a low rate (overnight charger, essentially).
If you use a LiPo battery with your Aurora 9X then you need to remove the LiPo to charge it.
