I have just about finished the fairing that cover the landing gear mounting bolts . Also been fitting
the rad , I am making the rad cover the flap linkage , also applied some of the access panels to the bottom
of the wing for a little added detail (from clark industries) I have ordered the hardware to replace the
temp cap head screws holding the retract covers in place (will be using flush mounted screws so they look
like rivets . Really starting to take on the look and feel of a real machine rather then a fiberglass shape..
Soon I will be hitting the lathe and machining up the 20mm cannons ,have the lighting kit so you can see the
muzzle flashes on the strafing runs.. .
