Hey guys, Hoping to tap into your experiences with the TopRC P51. I have the Robart electric retracts with the Robart retract control unit. My radio is the Futaba T12FGA. From researching this and other forums, I still can't find a solution for the gear door sequencing. I've read about the ESM and the Assan gear door sequencers. Its not clear from reading the instructions if either is compatible with Robart retract control unit and if the Robart CU can be used if using an external gear door sequencer. Also there's no information I can find that the 12FG can support a program mix to sequence the doors like most of the newer radios. I'd like to know how you guys would add door sequencing using the hardware I have. I'm open to other external sequencers or other hardware to make it work. I'd appreciation all input!
Keith
