You dont really need the tooling gelcoat,at all.Brush your resin on in THIN coats,smoothly.only 2 coats.Let the first go tacky(feel it sticky,but doesn't lift)before applying the 2nd.Then go ahead and laminate the cloth lightweight first,then 3/4 weight.No more than 3 coats or you will bake the surface.
