RCU Forums - View Single Post - 1/12 miss bud with 18 upgrade
Old 03-27-2018, 06:17 PM
boydog40
thanks for the reply, what im seeing so far is the 18 is of course a slight taller which in turn causes the manifold to sit higher which may cause some concern as to heat on the cowl, and not truly lining up with the tuned pipe mount under the wing.
ill keep you updated though, and yes i cant wait to see what the 18 will do in her!
