RCU Forums - View Single Post - balsa triangles
Thread: balsa triangles
Old 03-28-2018 | 07:38 AM
foodstick's Avatar
foodstick
Also if you are using the wood in front of the CG and weight is not going to be a problem. I often use square sticks... Simply because its ten times easier to clamp it in good and have it stay tight in the joint as your glue dries. White glue builder here so having the part stay in place for longer dry times is important.
