i layed up some parts. I know I used too much resin, on. At the time I didn’t believe it mattered. A put down peel ply(the econo stuff)and a couple layers of breather bleeder cloth and vacuumed them up. Came out like a solid rock. I used a grinder to remove most of it. So, did I use the appropriate material and method? Did I just use too much resin? Is there a different release film I should look into? When applied properly I should be able to, with effort, peel the peel ply and bleeder fabric off? Thanks.
