If the motor looses one of the three wires it will get out of sync as it work under a rotating magnetic field, also the two remaining wires will have an increase in Amps, so besides the noise the amps differential might make the ESC to shut off for safety (this is not on all ESC's so not really sure).
All the other options or cases are equally valid, this is just one more.
Regards
