I installed the rear end servos and control surfaces to see how it looks. I surface mounted the servos. Not sure if flush mounted would be better. What do you all think?
The tail surfaces are just about ready for sanding, sealing and covering. That will be the hard part; coming up with a covering scheme. I need to check the colors I have on hand. The fuselage is super strong with the top sheeting on. I pinned the dowel rod joiner on the elevator for more strength. Slowly coming along. This week I need to make the main landing gear
