Originally Posted by
Extreme_RC
Maybe email taft, he is usually pretty good with responses and likely will email you the manual, might even help you out with ordering parts.
I emailed Taft 3 days ago explaining my problems with my Quantum EDF... I can not get the front gear and door to operated... I believe it is a wiring problem and I need to see the proper wiring connection that they use for the nose gear....There are 3 different wires coming from the nose gear and door... the wires do not match in length or colors so I may need to correct this.... Thanks... Richard
