Test runs of the new motor.
Much better results with larger ESC.
After some fine tuning of my modified new rotor the longer can motor seem to run nice while testing couple of speedos, the larger HW120 runs lot cooler than the FW130, which I put more like 100A basket case. Next job will be thrust test to see if there is any difference to my poor 1.55kg using the stock set up.
