Starting My Kaos!!!!
I am starting my Tower Hobbies Kaos 60!!
First question. The last Kaos I built was not a Towers Kit, I believe it was the Great Planes. That kit the wing ribs had tabs on the back of each rib to keep the wing straight. As can be seen from the photo this kit the ribs are, well, just the ribs. It mentions the holes are for using a wing jig. I don't have one and have never used one. Is it better to use one or can I make measurements and support the back of the wing in several spot to keep it straight? And if you suggest a wing jig, it is as simple as making one out of wood clamps on the ends and "What do you use for the rods"??
The manual for the build... And the plans title section with a wing rib... See the holes for the jig... Should I use one????
I
