First I pulled the fuel tank back and removed the clunk. Its preinstalled but as president Reagan said trust but verify 😎. Reinstalled it after safety wiring all fuel connections. Now you need to install the fuel vent while the fuel tank is slid back right under where the tank sits. Next up I installed the pump and ecu next to the uat. Next drilled 2 small holes in the mounting brackets that are preinstalled on the fuel tank and installed screws. I then had to drill 4 relief holes for the turbine mounting screws and mounted the turbine. Next screwed in the pipe.
Relief holes for turbine mounts
