Old 07-13-2018, 07:58 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Are you wanting to get to a good IMAC setup? If so what worked well for me was to move the CG so that from an inverted 45 it would take 7 seconds to arc to inverted level hands off. From there you can start adjusting the uplines and downlines. Most guys initially use way too much throw. 15 degrees up and 18 degrees down is all the elevator you should need. You will need a good dose of expo as well. If you are used to a sensitive setup this will feel odd to you but you will adjust to it.
