Originally Posted by
stearman65
I have now re-gigged the bedroom to house the building board. I'm still trying to persuade my wife that we need one more furniture move to make things viable. Tyhe final building surface has still to be obtained. Someone on an English forum suggested plasterboard, I was going to use ply. So before the weekend I will be going to a builders merchants who stock both, with a supply of pins to test before buying. The table is & filing cabinet are from Ikea, the table measures 150 x 90cm.
I don't know if I'd have the guts to tackle a build this big in my bedroom!
As for a building surface, regular plywood might be hard to pin to. If by plasterboard you mean what we call drywall or sheetrock in the US, then I do know that some people use that. Other popular materials are ceiling tiles (like the one used in drop ceilings) or foam insulation boards. I would bring a few pins to your building supply store and see what feels like it will work best for you. I use a 2' x 4' balsa building board I acquired some years back.
Balsa building board.
