Originally Posted by
Jeff Worsham
I should have included that my ESC high endpoint and throttle ATV are set such that 72A is the max I've recorded from the Mezon logging. Normally it runs 69-71A flying AMA Masters. Last year during the first test flights, it was logging 90A peak so I quickly dialed back endpoints. (was more power than I needed too) Recent checks prior to my last failure in June still showed 70-72A peak. That should be plenty of margin for an ESC rated for 90A. Short of installing refrigerated air, I feel like I did what I could to keep the C54 and Mezon 90Lite cool.
Yep, cooling looks reasonable to me. Surprised you're seeing such high currents from the CRS/C54. Are you using the recommended props?
The maximum I've seen on my CRS is 73A peak or maximum and I don't use any limiting at all. The average current (throughout a flight) would be much less than this figure.
It would be interesting to know what your ESC temps are. I've not measured mine but it's limited to 100C which I believe is the default.
Regards,
Jason.
