I found the main gear toe in angle to be excessive on both sides. Still not sure how to fix the problem yet.
Projecting wheel axle location to table
Marking tow in angle line parallel to tire
Marking line parallel to fuse through the wheel axle location
Measuring angle of toe in
Right main wheel has 6 degrees toe in
Excessive toe in
Left main has 5 degrees
Excessive on left also
